Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
342 Questions View all
What's the secret to the LCD shield screws?
I can't get the screws on the sides of the LCD shield off without stripping them. I've tried JIS000 and 00 and still can't get them out without stripping them. Are they 0000? Is there some secret combination I'm missing?
As penance for my ignorance, here are some pics of a phone:
Score 2
Comments:
What a pro lol
by
I couldn't get the LCD shield screws off either they wouldn't turn. I went to a store here in town and he said his trick was to place the screen/part over the edge of a flat surface like a table or kitchen counter. I could get 3 of them off but not the other side. He placed it up against the counter edge and didn't have problems taking out the problem 3 screws. Try that next time. I know I"m getting a premium screwdriver set too mine aren't cutting it.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
You need a 0.6mm Tri Point screwdriver. It is a Y shaped tip.
What happened to this phone that it is bent?
Why don't you have the screen off so you can get at the screws?
Also, you must hold a finger at the end of the screw for more rigidity.
Comments:
I really hope you can tell the device pictured is a 6 and not a 7....
by
Add a comment
Seeing that your phone bent in a cure there is a possibility that the screws got bent as well if you can find a small screw driver to use then use it. If you still can seem to get the screwws out go to you local apple store and ask if they can do anything to help you.
Score -2
Add a comment
Add your answer
Josh W will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 216
