Hard reset failed, Odin failed too
My tab 2 hard reset windows displays message in red font " did not match sized ' /system/csc/common/system/csc/others.xml' (No data available)".
I did the wipe data/factory reset but to no avail.
All data in tab remains intact even I did the wipe cache.
Deleting of whatever data was not successful since data will be restored again once deleted, for example; whatsapp or sms conversation or any data deleted will be restored once tab rebooting. They seemed deleted but they are not.
However, occasionally I experienced the tab resetting and initialised, and then asking to input first time setting. Half way through the tab rebooting and I have no time to complete that initial setting, and it goes back the reboot loop again. Rebooting loop occurs at every less than 1 minute interval.
I tried to restore its firmware update via Odin, but the Odin process failed after download process reached at final stage.
Battery condition is still good.
Anyone experiencing the same and successfully cured it, kindly share your solution with me , thanks guys.
Score 4
3 Comments
I'm From India My I9082 Dosen't Flash And Hard Reset Faild ''did not match sized '/system/csc/common/system/csc/others.xml '(No data available) Showing HOW TO FIX IT ?
by
Hold on, this is waiting to be approved by appuals.com.
Hi I have the same problem of multi-restarting, but it only comes up when only open the network (mobile data) other wise its normal and fully working. please suggest me a solution I've a lot of works inside that phone. When performing hard rest, it shows this dialouge: did not match sized '/system/csc/common/system/media/audio/ringtones/Samsung_Song.ogg' (No data available)
by
I have the same problem too, Hard reset not working, odin failed. Samsung Galaxy Tab 2 GTP5110 any help please
by
Add a comment
Most Helpful Answer
This message means you may be flashing the wrong image for your tablet via ODIN as well. Try another image.
Look through these forums.
https://forum.xda-developers.com/galaxy-...
I would say switch to LineageOS, as that works better.
Follow the instructions on loading TWRP, rooting, and installing LineageOS 13 via this forum.
Score 1
2 Comments:
My P5100 tablet keep restarting after just 1 or 2 minutes, so it gives me no time to root or install anything. I would love to install any other OS instead but I can not even factory reset the tablet.
by
نفس مشكلتي
هل وجدت لها حل
by
Add a comment
did you fix your's problem?if yes, how did you do it, because I have same problem
Add a comment
Add a comment
Add your answer
qawsme will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 14
All Time: 6,950
