Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Screen discoloration in top right corner of iPhone 6 Plus, please help
I replaced the front panel on an iPhone 6 Plus last night. I tested the LCD before installing all of the components (front camera, speakers, home button, etc.) into it, and it seemed to work fine. I even did one more test run before I closed the screen to make sure all of the cables were connected well, and it worked perfectly. When I closed the screen, however, a bright spot had appeared in the top right quarter of the phone. I have had two other 6 pluses with identically shaped and positioned bright spots, so something I am doing wrong must be causing this. Please help me with any information you know.
Score 2
Add a comment
Chosen Solution
It would be helpful if you posted a picture (you can add it to your question).
Generally speaking, white spots are caused by pressure. So if you have a bright spot in the top right corner, look at the camera and screen bracket area for something that isn't installed or lined up properly. It could also be a batch of poor quality screens where there is some dust or something else sandwiched between the LCD and backplate (this would be a very small white spot though).
Score 4
1 Comment:
I had a white spot also. It was the battery pertruding slightly on the upper left edge (original battery and screen). I solved it by lightly pressing down the edge of the battery with the flat end of a plastic spudger.
by
Add a comment
i think it has no solution take it to apple authorized centre
Score -1
Add a comment
Add your answer
Garrison Bates will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 6,108
