Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6S refurbished screen doesn't fit from bottom
Hi, I brought a refurbished lcd for my iPhone 6S everything works fine, but the bottom of the screen is not fitting properly, the seller claims that this screen is refurbished using machines, the lcd is real but the glass is new as they fix smashed glass lcd. I don't know what to do, it's is bottom which is lifted a bit and I cannot squeeze it inside the housing. Please help.
Thanks
Add a comment
1 Answer
Most Helpful Answer
Is the frame dented in any way? Any warping in the frame will not allow the screen to sit properly and put unnecessary stress on the screen. You will need to bend or mould the frame into a better shape if this is the case
I would remove the stock adhesive from the top of the frame as it may be getting in the way of the hinges.
Hope this helps
Score 1
1 Comment:
I will try it today an I will let you know if it worked
by
Add a comment
Add your answer
Mirza Zohaib will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 345
