Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Replaced battery, phone overheats and won't charge past 50%
Hey i replaced an old battery for a friend yesterday, He told me today the phone gets pretty hot and won't pass 51% when plugged in, When putting the battery in I may of done it crooked and I was having a bit of trouble getting the connector in, i had to bend the cable a small amount and i finally got the two prongs in and put a screen on to make sure it powered. All worked so i put her screen back on, the connector didn't sit flat which was strange but it worked so i figured it would be all good. I'm thinking the issue may be because of what i am talking about above, i'm gonna take her phone apart again and redo the battery connection and use a new battery incase I damaged it. But yea I think the connector may not be seated correctly, do you think that is my issue ?
Add a comment
1 Answer
In the shop we use a tool called iBackupBot which allows us to see battery info. I would have a look and see if the battery is 500+ cycles.
If the battery was genuine i cant imagine you would have this issue. Try put the other one back in (if you can) and see if it charges past 50%. If it does, i would suggest getting a different battery to install.
Hope this helps
Add a comment
Add your answer
Ian Romprey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 16
All Time: 118
