2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
189 Questions View all
Ports on right side of the laptop doesn’t work & wifi not detected
13” Mac pro late 2012 (model A1425)
Drop off from 1.5 feet onto the carpet in flat position
no scratches or appearance damage occur.
But it effect
1. airport module is not detected (wifi no hardware installed error)
2. USB, HDMI & SD card slot on right side of the laptop doesn’t work
I have removed the airport card and installed it again but hardware is still not detected.
I would like to know:
1. It can be fixed only by replacing whole logic board or
2. It could be another minor disconnecting problem* Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
Score 1
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Reseat the I/O cable (which goes from the logic board to the I/O board) and replace this if it is still not working. This commonly goes bad when dropped, and transfers all signals from the side board to the logic board.
Don't replace your logic board; you will have the same issue since it is just the cable :)
Score 3
Add a comment
I was wondering if this worked
Add a comment
Add your answer
ZebBilly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 268
