Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
changed the battery on I-phone 3gs , but new battery died
I ordered the fixit battery replacement kit for the I-Phone 3gs, and I completed the swap-out of the new battery, however the battery died less than three days later. and Now it would not charge at all. this was what happened to the first battery that came with the phone. is there someting thatcan be done?
Add a comment
Chosen Solution
Sounds like you have more than a battery problem. I get the impression that you phone is not charging. I guess you could check with your cable. Make sure it is in good working condition. Have you tried to charge from a AC charger as well as a PC? Any difference? Check your connector on your phone. Make sure there is not debris, clean with qtip. Worst case scenario you may have to replace your charger board i.e http://www.dealextreme.com/details.dx/sk... Now I also remember having read that some people had success by replacing their SIM card, but have not be able to verify this. There is alos an interesting idea out that involves the "fuses" for the charging and you may check into that as well http://forum.gsmhosting.com/vbb/f631/iph... Good luck
1 Comment:
The Charger Cable is OK as other mobiles is charging on the same charger ....also my mobile is also charging only when we switched off the Mobile but when switched ON it doesn't charged at all
by
Add a comment
I had the same problem. I just switched to the computer and it now works. Thanks!
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 742
