The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Questions View all
HDD issue, board loose and not seating correctly
is there anybody on that has experience with one of these? i am having to apply pressure to the board that sits to the right of the HDD (headphone/usb/memory card ports). it does not seem to be seated correctly and if i do not apply pressure then it does not read the HDD and continuously boots into BIOS. when it works, it works fine, but i am curious to know if there is something i can do that will fix it for good. i can take pics if needed. thanks
Score 1
Add a comment
1 Answer
Chosen Solution
@snapplekisses, Snapple, Perhaps the link to guide below will help you disassemble the laptop to check/ reseat the HD or see if fastener/bracketing/cable/etc. is the issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Asus X555LA-SI305041 Hard Drive Replacement
Score 2
Add a comment
Add your answer
snapplekisses will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,016
