Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
There is a discolored spot in the middle of screek when it's popped in
I'm repairing a 6 plus, and it has a discolored spot at the top of the screen, a little to the right. I tried loosening the earpiece bracket screws since I've heard this can cause discoloration but it didn't help. The discoloration goes away when I test it before closing it up, but once I pop the screen down into place it shows up again. I'll be grateful for any help.
Add a comment
Most Helpful Answer
Try removing the upper left screw of the plate holding the lcd/digitizer/camera cables. It normally do the trick.
Edit 13/06/17
Look at the flex bend (Red Circle) and at the metallic part (Blue rectangle) if they are properly sitted , this should be under the metallic backplate of the screen.
Score 1
1 Comment:
It didn't work. Think it may have something to do with the shield plate maybe? I moved everything over to another LCD and had exact same problem but couldn't see anything obvious that'd cause it. Strange...
by
Add a comment
Do you have the ability to try a different glass/lcd, so that you can isolate this to a part issue or a board issue? Also, make sure there is nothing out of place on the device that could add a pressure point causing the discoloration.
Add a comment
Add your answer
Garrison Bates will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
