on switch is loose/ doesn't turn on
I found this camera at a garage sale for $2.00 knowing it was broken. the on switch is loose, doesn't make contact.
TomB _, Did a search for S4830 Gyde with no luck. Found disassembly guides for the S4800 not your exact model but may help you get into the S4830 to check out on/off switch to repair/replace if required. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
All of the finepix cameras are similar enough so that if you understand one, the others simply need a little "checking around" to find out how to diisasseble the others. Note, you typically only need to take off the back and the top covers to expose the on/off switch and its circuit board.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 578
