4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
My phone won't turn on when I plug it in and there is a shaking sound
i plugged my phone in with several chargers and none of them worked and i can't even power on my phone now and there is a shaking noise inside my phone and idk if that is why it won't work or its because of something else i need help please! i can't bring it to the shop either i want to do it from home.
Add a comment
Chosen Solution
You'll want to start with a new battery, and see where you get from there. You'll also want to stop using aftermarket chargers, as they don't give your phone the correct voltage it needs. Use original Apple chargers
iPhone SE (1st Gen) Battery
iPhone SE Battery Replacement
iPhone SE (1st Gen) Battery Image
Product
$29.99
Score 3
2 Comments:
so if i use my origanal charger will it work..?
by
Yes. You're supposed to use your original charger
by
Add a comment
It sounds like the phone is working correctly but the screen is dead. The vibration you are hearing is the noise iPhones make when they are plugged in and on silent. Un-mute the ringer switch and see if you hear a sound.
Add a comment
My phone started doing the same thing, since this was a while back did something work?
Add a comment
Add your answer
madison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 843
