Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
sometimes restarts after touch ic.
hey people, i did an meson ic repair, but the phone restarts sometimes. also the visual disapears sometimes, when putting the lightning cable in for example. and sometimes when i start the phone there is no backlight and visual. and sometimes its bootlooping. what could this be? do i have to search around the dock connector? or is this something where the backlight filtes are?
hope somebody can help me.
1 Comment
* its not bootlooping anymore. after the first meson job i started the phone and touch worked. then suddenly te phone restarts and no touch. after the the second meson touch was back, but the boot problem is still there. the was not too much heat on the board.
by
Add a comment
1 Answer
Chosen Solution
My suspicion would be too much heat, even if you don't think it to be the case. The edge of the CPU and you also have a row of passives that affect the camera, backlight etc directly opposite Meson. You may also have shorted some pins underneath Meson.
At this point you could try pulling Meson again, inspect the M1 pad (for your touch issues) and try booting the phone without it. If it still bootloops, then your problem is elsewhere.
Score 1
1 Comment:
thans for your answer! i will try, but touch works perfectly so meson should be fine right?
by
Add a comment
Add your answer
thieske will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 813
