The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 Questions View all
What controls the power windows, the body module?
2002 Jeep Grand Cherokee
My windows and control panel on the drivers door no Power for windows or door locks, my interior lights work differently on the directional lever. Is that controlled by the body module, and where the heck is that modules model number.
1 Comment
bajapatrick all the other controls are working? the only one not working is the one in the drivers door?
by
Add a comment
1 Answer
Chosen Solution
If the problem is only on the drivers door then the problem will probably bee the wiring going through the hinge of the door . Find the power on the inside of the car just at the door and see if you have voltage there then check the wires and connectors where they plug in at the door and in the pillar. This is likely to be your fault area Thisvideo showsthe way to expose the wiring Hope this helps
Score 2
Add a comment
Add your answer
bajapatrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 681
