Device won't power on and charge
I opened the tablet to remove a stuck micro SD. After I put the device back together, it now won't power on and charge.
I'm not sure if how I did is a factor but here goes: I used a plastic card to pry off the back cover and used a screwdriver for spectacles to remove the screws. Did all this with my bare hands. I also used a used soft-bristled toothbrush to dust the insides.
4 Comments
Did you disconnect the battery?
by
Not that I am aware of.
I just lifted the entire PCB along with the battery to get to the dislodged microSD.
I also tried plugging it in then pressing the power button for 30sec.
by
That could be why. You might have shorted something out.
by
Is there a way to confirm this?
Also, why would it have shorted out?
by
Add a comment
1 Answer
Chosen Solution
@fpjones3, Fred, I do not own this device, maybe try disassembling the device again and check all the connections/wires and for any loose/damaged/burnt components. Undo the connections and reseat them to ensure there is good contact. You could also check the battery voltage and charger to ensure they are working with a DVOM. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Score 2
2 Comments:
Thanks L Pfaff. I do not know how to use a DVOM though. I'll see what I can do.
Cameron (above) mentioned it might have shorted out. What could have caused it?
by
Fred, Yes leaving the battery in when working on a device is not a good idea as you could accidentally cross contacts on the board causing short or if you do not ground your self when working on a device you could let off a static discharge also. Best to also check all the connections and reseat them and look/probe gently(tooth pick) for any loose/damaged components. Below I will post a guide on how a multi meter can be used, there are also a lot of other good guides available on the Net for viewing.
How To Use A Multimeter
by
Add a comment
Add your answer
Fred will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 102
