Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3621 Questions View all
The front facing camera no longer works after battery replacement.
After an iFixit battery replacement for an iphone 6, the front facing camera no longer works. The battery replacement was uneventful. I did have to disconnect the screen (as per instructions) to remove the battery. Used the spudger to reconnect the ribbon cables. Didn't see anything loose at the cable connections. Any way to troubleshoot this?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Ok, so you've either not connected the cable properly, or damaged the cable, or you've damaged the socket. Also, check that back camera cable, make sure that's in there good too. Come back if you have any more questions
Score 2
Add a comment
Add your answer
ddarden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 24
