4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Repaired iPhone, now phone is not turning on
Hi
My iPhone's back camera is quite temperamental and sometimes if dropped disconnects and doesn't work - I know the problem is not that the camera is broken only that it is a connection problem because I have fixed the issue before.
This time, after putting my phone back together the phone will not turn back on at all. Itunes recognises the device (however I can't restore it because I can't respond on my iPhone when prompted to allow the computer access). I have tried to hard reset using the home and power buttons and it did not work. The only problem I had when repairing the phone was losing a screw for the logic board cover but I didn't think this would cause this kind of issue?
Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
Try shining a bright light on the screen, if you can see a faint image then the back light IC has blown (normal due to the battery still being connected when the screen ribbons are removed), if there is no image id try a new screen..
Score 5
3 Comments:
Rayeasom, you should set up a username (like @rayeasom) so that we can contact you directly. I wanted to let you know that someone had copy/pasted one of your comments as their own answer but there was no way to directly reach you. I moderated your comment into a answer so that you can get properly credited and be made aware.
by
No worries...but my username is @refectio :>)
by
Add a comment
Add your answer
julia n will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 137
