Can I use the galaxy s3(i535) on ne1 use att's hspa network
How can i acomplish this, i put the apns in, turned it to global and inserted the sim card. I understand att shut down their edge network. So can i use it on atts hspa
Add a comment
1 Answer
Most Helpful Answer
The phone does not support AT&T LTE.
However, it may be unlocked to support 3g on the 1900mhz frequency.
I would say if you have a Cricket or AT&T store, walk in and simply have them test the phone.
If it does support it, Cricket/Straight Talk/Net10/TracFone will send you SMS that auto configures your phone's APNs.
For AT&T, you may get the same, or you would need to manually put in your APNs, and it would work.
IF not, you would have the extra step on getting the phone unlocked.
However, if only 1900mhz 3g/3.5g is supported, it would not work very well.
Score 2
2 Comments:
I can't get any signal, I've already configured my apns
by
1900mhz probably isn't in your area.
by
Add a comment
Add your answer
joey serenko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 40
