Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
IP6S screen works then goes black randomly, phone is still going
So iPhone is fully operational, screen is working, touch is good, but randomly the screen will completely go black. Sometimes after 30 mins, sometimes with 1min of turning on.
Any ideas of what this is and how to repairs?
Thanks
4 Comments
Did you try a know good LCD?
by
yes, screen went black just after passcode entered
by
What about the fpc connector? Also has it had water damage?
by
fpc looks good, no water damage as far as I can tell
by
Add a comment
1 Answer
Chosen Solution
This may be a backlight issue. The iPhone 6S does have a well documented history of this problem. When the screen goes black, does the phone appear to be working (receiving calls, text messages, recognized by iTunes)? If so, shine a bright flashlight on the screen to see if you can see a dim image.
That would indicate a backlight issue. It could be screen related or logic board related. Ideally, you would need to test it with a known-good replacement screen to eliminate a variable. Depending on your situation, you could try a screen from a different phone, or have a repair shop try out a new screen. If the screen doesn't fix it, then you will need to have it repaired by a shop that does micro-soldering repairs.
Score 2
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60,259
