I need help! I need a tear down guide for Everest 700
So my warranty on my headphones expired and the power button broke on my headphones. I try to press the button but it's already pressed down and it wouldn't click. I need immediate help to tear down these headphones!
Score 2
2 Comments
Did you find a way to tear it down, got the same problem
by
Does anyone know how to replace the battery?
by
Add a comment
1 Answer
Most Helpful Answer
So if you need to take apart the headphones start by taking off the earcup the move on to the four screws that hold the speaker on. Next there will be 2 screws and rubber tabs. Take out the screws then pull all tabs up don't rip them just straighten them out. Now look under the piece you were just working on. This should be the base were the rubber tabs enter the piece above. Gently pull where each tab would be untill all are removed. Now you should be able to get to the board of the headphones
Score 1
Add a comment
Add your answer
Garrett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,421
