4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 Questions View all
Will not turn on, no image on the screen.
will turn on, theres a green light indicator but no image loading on the screen, tried removng batterry and resetting by holding power button but wont do, when try to remove and re insert battery, green light indicator automaticaly turn on w/o sliding the power buttton on
Score 5
1 Comment
franklyn72001, did you get it fixed?
by
Add a comment
Most Helpful Answer
try to turn your psp on using charger and if you can connect it to a tv and see if the display turns on if it does then take it off display and if its still black screen then that means you have a backlight fuse problem.
Score 1
Add a comment
buy a new battery
Add a comment
Add your answer
franklyn72001 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 12
All Time: 5,205
