Problem turning over completely!
Hello, I have a 2004 Cub Cadet LT1024 Riding Mower and it is having a hard time cranking. Like it will roll over but stop in mid rotation and have to use my hand to help it rotate. Will never make a full rotation and will not start. I have replaced the starter, battery, coils, plugs, fuel pump. I have checked the carb and it is flowing like should. I'm at a lost and in need of help. Thank in advance!
3 Comments
Have you checked the oil? It almost sounds like its seized.
by
Oil is good just changed it. And motor is not seized can rotate it freely with my hand. Thanks for the input!
by
I have same problem with my LT1024 how did you end up repairing yours ?
by
Add a comment
1 Answer
Chosen Solution
Kersh test the voltage while the tractor is sitting without cranking then test it while cranking . If it drops a lot more then 1 or 2 volts then you may have a ground issue. try adding a ground by putting a set of booster cables on it .Attach to the negative pole of the battery and then connect to the bolt that holds the starter on the engine or onto the block somewhere . Hope this helps
Score 1
5 Comments:
Thank you I will check that and see if it works. And voltage is at 13.2 before crank and drops to 11.9 at crank. I will hook a extra ground and see if that helps. Thanks again!
by
Hi Kersh! Were you ever able to confirm this issue? Having the exact same problem myself.
by
I’m having the exact same issue. Any solution to this?
by
Did you figure it out? I have same problem
by
To anyone with this problem, i recommend looking at the first comment on this answer by @kershkeasler and hooking it to ground if that fails, then maybe try hooking voltage directly to the starter from an external source and see if that works.
by
Add a comment
Add your answer
kersh keasler will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 78
All Time: 4,869
