Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
35 Questions View all
Why is my cooling fan not working (90B)
okay I've had this PC for a while and all of sudden It gets stuck in a boot loop. When I ran a start-up test it FAILED
PROCESSOR CHECK : PASSED
MEMORY TEST: PASSED
HARD DISK SMART CHECK: PASSED
HARD DISK SHORT DST : FAILED
FAILURE ID:
M08881-6AN8K8-MFGK1F-60XC030
PRODUCT ID: C2M42UA#ABA
HARD DISK: 1
Score 2
2 Comments
90B is the cooling fan error. Sorry
by
updating the BIOS literally did the trick for me.
by
Add a comment
1 Answer
Chosen Solution
Hi Feeding Logic, here is what hp recommends you do after encountering this error:
''To fix this error, use the following steps:
If you notice that the system fan spins and is blowing warm air from the computer, clean the exterior vents to remove dust buildup by blowing air through the vent openings. Do this while the computer is off. Dust can accumulate inside the vent opening and around internal cooling components, preventing the removal of heat. After dust has been removed, try turning on the computer to see if the error goes away. if not, continue to the next step.
For more information on reducing heat inside your computer, see Reducing Heat Inside the PC.
Perform a hard reset. Performing a hard reset can reset recorded thermal values in memory and enable you to use the computer again — even if only for a short time to access and save any important files before service. For information on performing a hard reset, see Use Hard Reset to Resolve Hardware and Software Issues.
In some cases, updating the BIOS may help prevent this error from occurring. For information on how to update your BIOS, see Updating the BIOS.
Have the computer serviced to clean internal components and replace the system fan if necessary. Ensure that the following items are addressed during servicing:
Thoroughly remove dust from all internal cooling components.
Ensure that wires from the system and CPU fans are connected to the motherboard securely.
Ensure that the system fan blades spin correctly, and that the fan is not producing loud noises. If not working correctly, replace the system fan.
Remove old thermal compound from integrated circuits and heat sinks, and replace with new thermal compound.''
Alternatives
Here is one video pertaining to a fix for this issue.
Here is another video for a visual guidance on cleaning and disassembly
-Let me know if this helps
Score 5
1 Comment:
clean the fan and heat sink
dust clogs the fan causing the fan problems to spin freely . cleaning the fan and heat sink worked for my laptop fixing the error code 90b along with it :)
by
Add a comment
Add your answer
Feeding Logic will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 36
All Time: 89,075
