Why won't my radio work
I've been adding new items to my mazda mx-5 and now the radio doesnt work can anyone help?
george100 , If radio asking for a code use the 1st link below or contact the dealer for code if not stuck in your manual or inside glove box liner.
If not asking for code and no display, check for blown radio fuse(check all fuses), if all fuses look OK you will want to unplug the radio and check for power at the radios plug, with ignition in on position. No power showing at plug would mean break in wire or you may have missed blown fuse. Trace radio harness for broken wire and check plug for corrosion/damage terminal. If there is power at the plug, the radio has a internal fault and will have to be disassembled to find/test for bad components or replace radio. 2nd link shows how to remove the radio. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,601
1 Comment
Hi,
Have you checked the fuses?
What new items?
by jayeff
