Repair for speakers, stereos, header units, and CD players for your car or truck.
247 Questions View all
Can you hook 4 speakers up to a amp,and then leave the 2 other...
Can you hook 4 speakers up to an amplifier. And leave some factorys speakers still connected to the head unit.
This is what I have done but now the factory door speakers do not produce that much bass like they were before.
Explanations comments excetera please
Add a comment
Chosen Solution
Ryan, Check out the links below, they may give you some good info on speaker hook up. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://arstechnica.com/civis/viewtopic....
http://www.termpro.com/asp/pubs.asp?ID=1...
http://www.ebay.com/gds/The-Experts-Guid...
Score 2
1 Comment:
Is it OK to have A Amplifier hooked up to a vehicleWithout having speakers hooked up with it
by
Add a comment
I wouldn’t run any factory speakers on an aftermarket amp due to poor quality of the speakers from the factory plus they are almost always lower impedance than aftermarket speakers and unless your amp can go down to that impedance it will just go into protect. But say you put 2 aftermarket speakers in the rear and hooked them up to an amplifier if the audio source is still the stock radio you will need to use a line output converter or make sure the amp you use has a high level input option and take the signal going to the stock speakers you’re replacing (most people find the rear speakers are easiest to get the signal from but depending on your car it could have a stock amplifier and alot of car manufactures have a cross over also built in and if this is the case then you’ll need to also get a DSP or bass restoration device because any low frequencies are rolled off and your speakers will sound clunky due to impedance difference from the factory speakers it’s built for and a subwoofer will just be a big speaker and have no bump) and run that into the amplifier then hook new speakers up to the output of the amplifier and make sure the amp has a high pass filter and it’s turned on then with all the power cables ran you’re good to go.
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 55
All Time: 1,810
