Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6s won't turn on and itunes says there is no SIM card installed
I had my iphone 6s screen replaced today. When I went to pick it up, the tech said that the home screen wasn't working and had to do a bit more work on it. He put my code in, seemed to be able to get it working, but then mentioned he had to reset it. He then tells me there was a problem and that my phone had "touch disease" and that the backlight won't work and suggested i get it replaced under warranty (which i know is nullified due to me choosing to go to a third party repair shop). He said it was working when plugged into the computer but when I did it, itunes says theres no sim card installed. I'm unfortunately not very knowledgeable about the ins and outs of iphones but is it likely that the tech did not put the sim card in? it will not turn on at all, so i'm at a loss of what to do. if he does have the sim card, is there a way i can remotely deactivate it or is my info compromised? Thanks in advance for any insights you can offer :)
Add a comment
1 Answer
Chosen Solution
So for Apple iPhone warranty. The warranty is not voided if an original screens is installed on it.
If you bring it to apple with cracked screen or aftermarket screen install that usually makes warranty voided and is recorded in apple's record if they have inspected it.
My bet is the person that repaired the phone blew the backlight circuit because the battery was not unplugged when the screen cables were replugged.
And for touch disease issue that is a lie as that only applies to iPhone 6 and 6+. Not 6S or 6S+ as the touch ic controller chip is on the screen and not the logic board which iPhone 6 and 6+ have.
Score 2
Add a comment
Add your answer
billy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
