The Samsung Galaxy Tab 4 10.1 is the fourth generation of Samsung tablets that has a larger screen, higher camera resolution, and 1.5 GB of RAM.
15 Questions View all
My tab 4 screen doesn't work
Hey, my tablet screen went black but the tablet works you can hear charging sounds.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
The Samsung Galaxy tab have a issue with there batteries . This may be the problem ,you can resolve the issue by disconnecting the battery and then reconnecting after a minute or so of being unplugged. While you have the tablet open it would not hurt to inspect the display cables to make sure there plugged in properly . This guide will help with the opening and unplugging of the battery , you dont need to remove the battery just unplug it
Samsung Galaxy Tab 4 10.1 Battery Replacement
Hope this helps
Score 2
Add a comment
Was it dropped? If it was dropped, the cable that plugs the display into the board could have come out causing the screen to go dark.
If not dropped, it might be possible that the display unit needs to be replaced.
Cheers
Score 1
Add a comment
Add your answer
Taric Butter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 115
