2.26 or 2.4 GHz / White plastic unibody enclosure
618 Questions View all
MacBook A1342 won't power on after replacing display
I replaced a defective display (side connectors failed) on my otherwise working MacBook A1342. Ordered a used display assembly and followed the directions here. Now it won't power on, and when I connect to the power adapter I get a solid green light. Followed Apple's troubleshooting procedures with no luck. Any suggestions, anything to look for before I tear this back down? Thanks!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Check all your connections, mainly the keyboard cable. Plug in the old screen to make sure this isn't causing an issue, although I doubt it. Try running it off of the charger with the battery disconnected too. Did you disconnect the battery whilst working on it, and did you disconnect it with a metal tool? You have possibly shorted something on the board.
Score 3
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 27
