An inexpensive 8-inch tablet with a premium feel. Released end of 2009
12 Questions View all
Doesn't let me update it
It stating doesn't have more memory even when the sd card doesn't have nothing on it
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
It's referring to the internal memory not sd memory .Updates need to be installed in the system which is on the internal memory Try moving some of your apps from the internal memory to the sd to free up space on the internal storage . you can also move music and photos to the sd card . Once you move them make sure to go back and delete whatever you just copied over otherwise your not actually making space your just backing up. Once you made room you'll have no problem doing updates. Hope this helps
Score 4
Add a comment
Add your answer
Mauricio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 54
