Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Water damaged iPhone 6 won't restore to factory settings
I'm doing my first ever water damage repair for a client and I'm having some trouble. Apparently the phone worked for the first two weeks, and he had the screen replaced by another repairer but then it stopped working completely. I changed the battery, and when I tried to power the phone on, the Apple logo appears for about 4 seconds then the phone powers off. I tried to do a hard reset, and the connect to iTunes logo appeared but plugging it in did nothing, so I replaced the charging port. Restoring the phone to factory settings appears to work, but then when the phone restarts after restoring, I just get the apple logo for a few seconds and then iTunes says that it has found an iPhone in recovery mode.
1 Comment
Did you clean the corrosion off the board yet?
by
Add a comment
1 Answer
Most Helpful Answer
@pod33 , Liam, You may have to put your device in recovery mode and set it up again. See the link below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://support.apple.com/en-ca/HT201263
Score 2
2 Comments:
I've tried that, after I connect the device to iTunes and restore it, I get a popup window from iTunes saying it's successful and to leave the phone connected while it restarts, but then when it restarts again iTunes says that it has detected a phone in recovery mode, and it's back to square one.
by
Liam, Sorry you are still having an issue. All I can suggest is for you to try it again following the instructions from the link. Good luck.
by
Add a comment
Add your answer
Liam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,252
