Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Why is my iPhone 6S won't keep on
After having a water-damaged, I went to the apple service, they cleaned the main board with special liquid, my phone can work again. After a week, my phone suddenly turned off, I charged it two days later and its working. Same thing happened again. I wonder if I should changed the battery because it is 60% when it went off, but it has no power when I try to charge it? I try to plug it in charging right away but it won't turn on, I have to wait at least a day after.
Or is it about the LCD cause the screen went blur before the phone turned off?
Your answer / help would mean so much to me, thank you in advance.
Add a comment
Chosen Solution
I'm surprised apple would even offer that. If they did not replace the battery then most likely the battery got affected from the liquid damage.
Score 4
Add a comment
Hmm Apple Stores don't do water damage repair in house, they only do basic repairs, or swaps. Was this an Apple Store? Or an independent shop?
Either way, in my experience once you get liquid in the device you are better off using your money towards a replacement, as opposed to trying to get it repaired. Even after you clean a water damaged board it may (and probably will) continue to have issues down the line. You will end up spending more in the long run. Since it is able to boot at the moment I would do a full backup and go through either your insurance, apple directly, or an online vendor to get a replacement
Add a comment
Sounds more like the Pmic chip Having contamination under the chip rust will cause many issues.
Add a comment
If you aren't expert in testing cables u need to take it to an expert so he can test cables and ic's of ur phone
Score -1
2 Comments:
You can't test individual ics on the board without taking the them off so what's the point?
by
there is a way by a flash which is connected at the same time with the motherboard to a computer and it will directly give u where is the problem on the board
by
Add a comment
Add your answer
raechalista will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
