The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1458 Questions View all
Stuck in bootloop, nothing works!
I have a customers iphone 5c and it is stuck in a bootloop on the apple screen. I tried disconnecting the battery. Soft and hard reset. Plugging it into itunes and attempting dfu mode but it wont let me get to the dfu mode reset. When it gets plugged into the computer it dings like it is reading the iphone but nothing shows up at all. I let it die and then charge it and it still doesn't work. Any recomendations?
Comments:
Thank you to everyone who commented! Installing 3utools and doing a flash solve my issue!
by
Add a comment
Chosen Solution
You mean your iPhone stucks in recovery mode right, you just need to flash your iPhone with iTunes or iTunes alternative tools, 3uTools.
If you fail to flash your device, please show me the error code or the sreenshot.
Add a comment
Most Helpful Answer
I guess you are not getting any error messages in iTunes. If you are, please let us know.
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Score 1
Add a comment
try tenorshare to unbrick your phone
Add a comment
Add your answer
cellphonebuyer1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 110
