2.3L 4cyl or 3.0L V6, 6th Generation
427 Questions View all
Clutch not engaging hydrolic fuel levels are fine but clutch doesn't
I hit the panel to the floor no tension at all
Thelse hydronic dot 4 level are fine. It just would not engadue. Last night was fine today not.
Add a comment
1 Answer
Most Helpful Answer
Tallat Mahmud , There may be a leak in the hydraulic clutch line, look under the hood and under the car to see if fluid leak evident and look at the lines and connections for leaks, if no leak observed probably a faulty/bad clutch master cylinder or slave cylinder(seals leaking internally) and has let air into the system. Below are links that will show or tell how to replace master and slave cylinder. Note the picture is of the slave cylinder, I have seen a few of these break at the bolt flange and then they swivel/turn and then the pin will no longer contact the fork, in this case the cylinder will have to be replaced also. Good luck.
https://www.youtube.com/watch?v=vOiHgP33...
http://honda-tech.com/forums/acura-integ...
Score 1
Add a comment
Add your answer
Tallat Mahmud will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 345
