Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Questions View all
broke screw bracket under LCD & batterry cover plate now won't charge
I made an error when replacing my iPad mini 2 screen when I had reconected the LCD screen and battery I went to put the small protector plate back on and used the wrong screw (slightly longer) in the left side bracket (the one closest to the battery) which caused it to snap off I didn't think this would be a problem as it didn't look like it was attached to anything important so carried on putting the the iPad back together I tested the screen everything worked fine up until it needed charging the iPad no longer charges is it possible I did damage the charger port flex or could it be something else thanks
Update (03/16/2017)
Update (03/16/2017)
Add a comment
Chosen Solution
I fear you have created Long Screw Damage on your iPad. It is a more common fault with the iPhone 5S/6 because there are traces directly beneath the standoff. I am not certain if there are any on the mini 2 as my software tool ZXW doesn't show any. That said, there could still be but because the problem is rarer, no on has mapped them out.
Can you post some pictures of your actual board...close up pictures? It may be salvageable.
Score 2
3 Comments:
Yes I will comment with more photos also the part that came off
by
It's hard to say for certain due to the focus being off but all of the surrounding components appear to be where they should.
At this point, if you want to save your iPad, you will have to find a shop that does micro-soldering repairs for a proper evaluation.
by
Thank you it worked fine just cant charge but it sometimes flashes up with the battery to say it's charging but then goes back to the picture of the lead with the lightning sign telling me to plug it in when it is
by
Add a comment
i did the exact same thing.....what did you end up doing
Add a comment
Add your answer
Sue2485 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 335
