Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone won't turn on, but will connect to iTunes
So my wife's iPhone recently "died". An alarm started going off and she went to turn it off, but when she did the screen just stayed black.
I followed some of the guides and other answers here and tried a hard reset, then tried connecting it to the computer. This is where it gets weird.
The phone connects to the computer with no issues whatsoever, the computer can pull data off the phone including serial number and all that. It was able to update the phone even (I attempted a recovery once it seemed like there were few other options).
However, when I try to interact with the phone it just stays on the black screen. I tried getting Siri to activate with no luck, and when I move the silent switch it doesn't vibrate like it normally would. This makes me think it isn't just the screen needing to be replaced.
My initial thought is probably the logic board, but I'm not sure the logic board could be the issue if it is able to connect to the computer with no problems.
Thanks.
2 Comments
This may be a dumb question but have you tried holding home + power button for 10-15 seconds?
by
I did try the hard reset a number of times throughout the process. Even now it doesn't do anything sadly.
by
Add a comment
1 Answer
Most Helpful Answer
Before you get a new screen, go to a repair place and see if they will test it for you. If it works and boots up with a new screen, that's your problem. If not, then it is something worse.
Score 1
Add a comment
Add your answer
armytrixter85 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 47
