Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
iPhone 4 not responding to anything. Hard reset doesn't work, nothing.
Hi my iphone 4 recently just stopped working, it was on about 90% at the time. It wont respond to anything when it's not on charge, hard resets, you name it, i've tried it. Its just a rather expensive paperweight.
When i plug it in, and i press the home button it comes up with the low battery symbol. (black screen with a low battery symbol) then after about 5 seconds or so it goes to the apple logo as if you had just turned it on after a full shutdown. it does this for a while and then goes back to the battery symbol that i outlined earlier. it loops this infinitely until I take it off charge, where it turns into an expensive paperweight again.
Any help would be greatly appreciated!!
Add a comment
Best guess is you have used up every ounce of life that battery has. Try a new battery in it
Add a comment
multiple issues cause this. here is a list, and remedies to them in order of likelyhood
1) Bad battery: Your battery is likely draining at a rate faster than it can charge. Replace.
2) Bad charge port: Your charge port may not be giving current to your battery. Replace
3) Bad power button flex: Your power button may be shorted, making the device think someone is holding down the power button at all times. Replace.
4) Bad mainboard: Your mainboard may not be properly processing the current it is receiving. Mother board replacements are rarely worth the repair, though you may replace this to fix the issue.
Add a comment
Add your answer
Damon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 86
