The Visual Land Prestige 10 is an internet enabled tablet made by Visual Land INC. This device page and subsequent repair guides will show you how to remove and replace the devices components.
66 Questions View all
My tablet won't go past the "prestige" " Powered by Android" startup.
Visual Land Prestige Prime 10 ES With Keyboard
When I turn on my tablet it will not go past the Prestige
Powered by Android start up page. I've let it sit there for hours and nothing.
I've tried the reset button on the back and nothing. I've tried to hard reset with holding the volume+ and power button and nothing. I've tried holding volume+ first for 5 sec.then push power button and holding both for up to a min and a half and I get nothing! Help. Don't know what else to do.
Score 9
4 Comments
It still doesn't work. I tried the down volume button and power button at the same time and nothing happens. The screen stays black.
by
No only does it not power up, but the battery doesn't appear to be charging after being connected to power for hours.
by
Tried the power and down volume buttons 3d android appears but nothing else. Tried using the down volume button anyway but nothing. Also tried rest button on the back of the tablet
by
My computer won't work
by
Add a comment
Most Helpful Answer
tilamu123 , Try this, hold down the power button, and the Volume down buttons at the same time. Keep holding until you see a 3d android, lying on it's side.
Then use the volume down button, scroll down to either system reboot, or factory reset.
The reboot will just reboot your tablet and it should turn on and fix the problem the factory reset, will erase everything in the system. Use the factory reset if 1st reset did not fix. The factory reset will restore the tablets settings, remove SD card prior to reset. You can also check the trouble shooting link below for for more info. and step by step factory rest procedure. Good luck.
Visual Land Prestige 10 Troubleshooting
Score 1
3 Comments:
I tried this and it still doesn't work.
by
tilamu123, Did you try the factory/hard reset suggested if not try it now, if that does not work us the link below to disconnect the battery for an hour and reconnect it. Good luck with your device.
To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen does not work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Visual Land Prestige 10 Battery Replacement
by
Since my touch screen doesn't work I can't even power down!
by
Add a comment
My tablet it keeps telling me that Google has stopped
Score 1
Add a comment
Cant get passed Android screen tryed everything youve suggested waste of money im dissgusted by this
Score 1
Add a comment
Same, stuck on powered by android. I've tried wipe cache, and user data, reboot. Nothing. Just still shows the same thing. Anymore ideas before I introduce hammer or axe?
Score 1
Add a comment
Ive looked all over, and I think it means it is out of luck, it seems to be a scam by the company to make you pay for more fixings for it?
3 Comments:
8. After the wiping select Reboot System Now. then after that back to proscan froxen screen, I am believing more and more that this is a scam
by
I guess most people gave up on this piece of junk, shaddy company
by
Dosent work tryed what youve suggested cant get pass Android
by
Add a comment
How do I get to work where I can touch screen
Add a comment
My tablet wont even go into the boot screen.
Add a comment
My Visual Land Prestige Elite 9Q did this and i held the Volume up + the volume down + the power button until the recovery screen came on then i wiped the cache then wiped all user data. Then rebooted the system and my tablet came back to life.
1 Comment:
I did that an it just took me to the powder by android screen. My child had not had this tablet a month an now it won't go past this screen. Help please
by
Add a comment
Add your answer
tilamu123 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 8,608
