Repair guides and support for your Samsung TV.
2620 Questions View all
Tv flickers with pink color lines, sometimes it go blank.
My Samsung LN 4081F Flickers with green and pink color lines sometimes it goes blank but still have sound. i turn it off then turn it back on and it fine for awhile, but it periodically flickers again.
Add a comment
1 Answer
Chosen Solution
@save1028 possibly a bad t-con board. It would help if you can post some images of what your screen looks like with those lines. Post some images with your question by using this guide. You will eventual have to remove the back of the TV (after you unplug it) and check things out. Check to make sure that all the cables are properly seated and not corroded. Check the boards for any domed or leaking caps as well as other obvious signs. Again, posting some images of those boards will help us to help you.
Score 1
Add a comment
Add your answer
Stephen L Avery will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 998
