Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Can't hear after battery change
Changed battery on iphone 3g every thing went great game and app sounds work great but I can't hear when i try to call...I have took it apart 10 times everything is right! HELP... and the Mute button is not it up
Score -1
Add a comment
1 Answer
Chosen Solution
earpiece is on connector 3, try reseating this and check for damage to connection/flex. app sounds run off main speaker on the dock connector which is why they still work.
mute button needs to be checked that little plastic toggle on flex is on groove inside the mute switch-it is fiddly and time consuming. sometimes if you stick the mute button from the outside of the phone (in down position) it leaves you 2 hands free to put flex toggle in properly.
Score 1
5 Comments:
Where is the toggle at for the mute switch? thanks for all the info....
by
at the end of mute flex is the metal connection and on the other side is a small(tiny) plastic switch-sometimes is red, sometimes black. this is the toggle
by
ok thank you I will check that :~)
by
ok I'm a girl and I can't find the toggle....I think that might be it because when i call out the mute button light isn't on.all the lights on the key pad is on but the mute button light...I can't figure out where the mute flex is
by
i'm a girl so maybe i didn't make sense.the mute button/vibrate flex is on the headphone/volume jack.
when i re read your original question have you missed out an "L" and your question should say mute button not "lit" up? as in the option for mute on your touchscreen isn't on?
by
Add a comment
Add your answer
Amey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,084
