Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Digitizer not working correctly. Some spots are dead, some are offset
I installed a new screen & digitizer. The Digitizer is not working correctly. Some spots are dead, some are offset. Like if you press "a" you get nothing. If you press "s" or "d" you get "a". To use the "Slide to Unlock" you have to swipe downward at 30-45 degree angle. With "Slide to power off" the first 75% of swipe doesn't register and the last little bit isn't enough to turn it off.
Add a comment
1 Answer
Chosen Solution
@tyoung489 , Timothy, Sounds like you may have gotten a faulty digitizer. Did your old digitizer still work, if did try reinstalling and if it works, the new one must be faulty.Return the digitizer for replacement/refund. Good luck.
Score 2
2 Comments:
The old screen / digitizer was shattered and I can't use it to test.
by
Timothy Young, Recheck your connections, if all look good, undamaged and secure, probable bad part.
by
Add a comment
Add your answer
Timothy Young will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 67
