Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
72 Questions View all
Backlight won't work after screen replacement
Good evening everyone,
I'm currently writing this because I haven't found anyone that has the same issue as I have. Briefly, I cracked my P9's display 2 months ago and since nobody fixes Huawei's products where I live, I decided to fix it myself by buying a new display on the internet.
At first, I didn't recognise that the display I recived wasn't the right one, the cable was black so it was supposed to be for the Lite version of P9 (great sellers...). As soon as I connected anything I turned it on but I could see pretty much nothing. Then I finally realized it was not compatible with my phone, then I ordered a new brand one once again, this time from another seller though. I was so happy that I could finally fix it and be sure it was going to be compatible (in fact it is compatible): same problem, I can hear every single sound, everything works but the display doesn't show up.
Now, I can see the screen with a lamp on it and the touch works perfectly, so surely the problem is the backlight that doesn't turn on at all.
Is it possible that I broke something on the mobo or the display that wasn't compatible messed up the display connector? I'm not trying to buy a new display because I'm mad at this and I won't waste a single penny on it furthermore.
Thank you in advance.
P.S. The displays are both Huawei original brand.
Score 4
1 Comment
i have same problem
by
Add a comment
Chosen Solution
I'm surprised people are blowing up backlight circuits for Huawei P9 screen replacement. Did you guys forget to unplug the battery first?
Score 4
1 Comment:
Actually I don't remember what I unplugged first, it could be that I unplugged the screen contact first, yes.
by
Add a comment
Hi, have the same problem, I think the backlight diode is not working but I don't know when is it placed on the mobo and how to replace. There is many issue on iPhone 6 but nothing on any Huawei
Score 2
1 Comment:
Hello do you know what the diode?
by
Add a comment
Try this solution and say thanks to the good man
http://forum.gsmhosting.com/vbb/f846/hua...
Score 2
3 Comments:
How do you short something?
by
Grand merci a vous les amis, ce poste m'a été d'un grand secoure.
by
Hello, i did everything like they said it in the forum, but the backlight still stays off. I'm not quite sure why, because everthing else works fine. Any ideas - Thank you.
by
Add a comment
Has anyone already found a solution? I think I screwed up the backlight circuit indeed. I did see the post on the jumper for a p9 lite.. but haven't found a similar diagram for the p9.
Score 1
1 Comment:
Same problem here, I can't find the similar diagram for mine P9.
by
Add a comment
So I had the same issue, I was able to fix it by following something i found on a forum that was mentioned here. See this diagram
Score 1
2 Comments:
Nice! Could you also post a link to the post where you found image? I need to know the second spot on the motherboard for the jumper. Or even better, how did you fix it?
by
I took it to a shop because I can't do the smd soldering myself. I think i paid €25.
I removed the motherboard and gave it to them so all they had to do was place the jumper. It worked so i'm happy.
by
Add a comment
any solution?? I have the same problem, my screen broke and I changed it by a new one that worked for an hour, but after that the screen turned off but operating system is still turned on, I have tried 2 screens and nothing, what is the problem??
Add a comment
Also looking for a solution to this. Unplugged battery as always before changing screen. 2 screens no backlight. Anyone know where the backlight diode is?
1 Comment:
by
Add a comment
I have probably the same problem. I have changed two LCDs the backlight I think isn't working correct because the lightning did not increase at all and some times the screen is flickering. I have changed and the battery but nothing. Any thoughts?
Add a comment
Hi
Try this solution
https://ibb.co/dBuiQ8
1 Comment:
This solution has already been givven 2 times on this thread. Why post it another time?
by
Add a comment
I have the same problem the diagram given before is different than for Huawei P9 EVA-L09
1 Comment:
does anyone have a diagram for a huawei x1? i blew the backlight and cant find any info what needs to be jumpered
by
Add a comment
The solution here aren't for p9, I'm still finding it difficult to rectify this problem.
2 Comments:
I still find it difficult to rectify this problem
by
They are for the P9, why would you say they are not?
by
Add a comment
Huwaei P9 Lite 2017 Pra-Lx1 backlight solution?
Add a comment
for p8 lite 2017? solution?
thanks
Add a comment
Add your answer
Valentino Poltera will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 36
All Time: 16,849
