Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1234 Questions View all
Slow, Randomly goes into headphone mode, wont record video
i have a bunch of issues with this phone so i will ist the issues here:
Wont record video on either camera, pictures work phone. already replaced camera with known good one.
randomly says in headphone mode, already tried new charging port
very slow, cant even play a simple game.
could i just reflow the board and see if that fixes it or should i just live with it?
Score 1
Add a comment
1 Answer
Chosen Solution
I would not encourage you to reflow the logic board. The component density is vey high, the pcb is very thin and multi-layered and the components are very tiny. Applying heat without knowing what you are doing is a recipe for disaster. You could easily blow SMD passives off the board (if using hot air) and/or cause solder ball explosions or shorts on the underfill-secured IC's or damage to surrounding IC's.
Score 2
2 Comments:
Could i heat the audio codec? I dont think that has under fill.
by
Do you have any reballing stencils for the iPhone? If so, then remove the chip and reball. Otherwise, you could try but it's just not something I recommend in a general sense.
by
Add a comment
Add your answer
Gigabit87898 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 56
