Line of mid-level Dell laptop computers.
969 Questions View all
After turning on, my screen won't stop jumping
I just got a dell inspiron N5040, and I turned it on, and the screen keeps jumping. Is this something I can fix on my own, or do I need to have it fixed by a computer repairguy? Please help me.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi,
Try connecting an external monitor and check its' display.
If the external monitor's display is also not steady then there may be a problem with the motherboard or the GPU or possibly with the graphics drivers. Try starting the laptop in 'safe mode' to see what the screen does.
If the external monitor's display is steady then there may be a problem with the video flex cable between the motherboard and the screen, with the video flex cable connections at either end (motherboard or screen) or with the screen itself.
Here is a link to a video which shows how to disassemble the laptop to gain access to the cable and the LCD screen.
http://blog.parts-people.com/2012/08/31/...
As with all electronic devices be careful when dis-assembling, with most there is no need to use force to disconnect things. Be gentle, you don't wish to cause more problems than you had before you started. If things aren't going as you think they should, STOP, take a break and think it through and then start again. This forum has a lot of questions from people who got frustrated and damaged their equipment. This is not to put you off, far from it.
Hopefully this is of some help.
Score 1
Add a comment
Add your answer
Gary Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 171
