Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
90 Questions View all
After reassembling my PSP Go the Start & Select buttons won't work
After i disassembled and rereassembled my PSP Go to fix my power switch; i used the PSP Go Teardown guide from this website, and now both the Start & Select buttons won't work anymore; and they were working before then.
so i tried taking my psp go apart and putting it back together again while going over the teardown guide thinking i over looked something, anyone have an idea of what that might be?
Score 3
1 Comment
This is how you replace it. https://imgur.com/gallery/JRRsJku
by
Add a comment
Chosen Solution
Look at the 2nd picture of step 9 in the PSP Go teardown. There is a cable that connects the buttons to the main board, it could be loose.
Score 3
2 Comments:
Here's a direct link to the page Aram is mentioning. PSP Go Teardown
by
thanks man, that's exactly what the issue was, i didn't see that cable cause it was hidden by joystick's ribbon cable.
by
Add a comment
I have the same issue, except my cable is in. Any ideas? I just had sound issue which was caused by bad fuse, which i replaced and now works but SELECT/START button doesn't
Add a comment
It comes out from the front. First detach from the motherboard and then take it out from the front. The Start/Select buttons are sticked on.
Add a comment
Add your answer
joel c will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 22
All Time: 6,178
