Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
5c got wet, hold power button and home button to restart and it dies
My iphone 5c got wet on the back housing by my kid and the screen couldn't display anything and became dark blue, and I saw dark light from inside, after dry the housing with tissue I held down the power button and home button at the same time for a few seconds then it died. I tried to charge it but the screen showed nothing, and I called it with another phone but couldn't hear the phone ring. After removing the screen I saw no sign of water damage inside and the water damage sticker is still white. I removed the battery and cleaned the logic board and inside of rear housing with disinfectant alcohol with cotton swab, after reassembling still it wouldn't turn on. It dies completely. I wonder if I got a faulty screen or logic board. Anyone can help? Thanks.
Score 1
Add a comment
Chosen Solution
As Ben says, don't waste your time putting a phone in rice....
You most likely have a logic board problem because most of the board is covered in shields. So any corrosion or shorts are probably not visible. That said, depending on where the water went, you may also have a bad screen.
If you want, you can try the following steps to clean things out:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
Score 5
6 Comments:
Thanks a lot.
Where can I get that isopropyl alcohol?
by
You should be able to find some at the pharmacy/drug store.
by
I cleaned the board and now I called the phone and I can hear the phone ring in headphone in another phone but the phone actually didn't have another sound. And it still won't turn on or cannot even display the sign of apple . It can be connected to Itunes which requires password for further operation. Is the screen faulty and needs replacement? But the water damage indicator on screen is still white.
by
Does the screen ribbon cable pins look burnt for the screen cable? The two cables and not the one for the front camera?
If yes then try another screen.
by
No. They look fine. Do I need to replace the screen?
by
Show 1 more comment
Add a comment
After water damage never push the power button before completely clean the motherboard. Methods like rise not working, you should use isopropil alcochol and completely clean the motherboard, remove the shields. Unfortunately you have a faulty motherboard now, maybe some resistors have oxidize and need replace. A technician should look your motherboard and replace the faulty parts, maybe faulty chips too.
Add a comment
Add your answer
Fernando Gonzales will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 194
