Why won't my phone turn on?
After not using my phone for a couple of hours, I realised it had turned itself of. I figured it might be low battery, so I let it charge, but I still couldn't turn on my phone. After that, I tried to take out the battery and press the power button for a minute, and then put the battery inside and turn on the phone. When that didn't work, I tried to boot it in recovery mode by pressing the power button, volume up and home button. I got no response. I have also tried two different charges, so that's not the problem. Really don't know what to do, so if anyone could help me that would be great!
Add a comment
1 Answer
Chosen Solution
Here are a few reasons, ordered starting from most likely to least likely:
- Battery gone faulty.
- Charger port is blocked or physically damaged. (if it's blocked it can be cleaned but have to be very careful, definitely check this first before replacing battery)
- An issue has occured with the logic board causing it to fail. (This is rare because phones rarely die like this).
Score 1
Add a comment
Add your answer
Ingvild P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
