How to remove my power seats, stuck back
My 2000 Honda Accord has a power seat on the driver's side which is stuck all the way to the back. How do I access the back 2 bolts to remove the seat?
ladyg94us , Check power seats fuses and look under the seat and see if you can see any wires that may be disconnected if power seat is not working, if looks normal procede. If the power seat will still raise, raise it as high as it will go then unhook your vehicles negative battery terminal to prevent possible shorting and air bag deployment. Normally you would move seat all the way ahead, you will just have to struggle a bit to do this 1st step ( a flash light may help) in finding the 14mm bolts to remove with a ratchet or wrench. Remove the trim covers/two plastic covers near the floor, covering the seats rear leg/track bolts (pry off trim covers and slide backwards) to expose the rear bolts(if equipped or not already missing). Remove rear 14mm seat track/leg bolts from both left and right seat rails to floor . Normally then then slide seat fully back(which yours already is) and remove front 14mm bolts from both left and right seat rails/legs to floor. Tilt the seat back a bit and disconnect the wiring harnesses. The pic's below may help for approximate bolt locations and the video link shows the removal process in your car. Good luck.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,010
