Anova heating doesn't work
My unit (Anova PC 1.0 BT) does not heat water, but the circulating system still work. The command pannel work, I set the temperature, the water circulates, but the Anova does not heat.
I disassemby the unit, but the fuse seems to be in good conditions (no burn glass, no broken filament). I tried to connect the two parts of the fuse with an aluminum foil, and it doesn't heat.
What do you suggest? I don't think that could be the fuse, but I don't know how to put my hands.
Thank you so much.
