Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
iPhone 3GS charges up to 1% and instantly dies, boots repeatedly
So I recently bought a new battery for my iPhone 3GS claiming to be a 1600 mah battery. However, when I installed it into my phone it was stuck at 69% so I tried to charge it to 100% to calibrate the battery. But it stayed at 69% I played a 10 hour long video till it finally died (oddly enough still saying 69%). So I charged it again but it was at 1% with the little outlet logo instead of the lighting bolt logo. And then it died again tried turning on by booting showed 1% and died. I have recently removed an ifixit battery that it previously had that expanded I don't know if it could have damaged the phone in any way. And the last time I checked it, it said 100%. But as soon as I unplugged it, it died. What is going on with the phone?
Add a comment
1 Answer
Chosen Solution
There is a "gas gauge" in the battery that communicates the battery charge level to the phone. If it is defective, then it will cause all kinds of problems.
Chances are you have a bad battery. Can you have it replaced by the supplier?
Score 3
Add a comment
Add your answer
alexandercisneros2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 79
