Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
battrey discharges fast and once it dies it won't get charged again!
Hi, i have an iPhone 6 with strange issue! the battrey discharges fast and once it dies compltly, it won't get charged again! I have repleaced the battrey couple of times and same issue so i know its not the battrey. What is the issue? how do i fix this?
Thanks for the help, i'm lost and stuck!!
Add a comment
1 Answer
Chosen Solution
If you have replaced the battery and you are confident that the batteries are good (can you test them in another device?), then I believe your problem is with the charging circuit (U2/Tristar).
This requires a micro-soldering repair and is not DIY unless you have the proper tools and experience.
Score 2
3 Comments:
It's gauranteed U2 Tristar charging ic gone bad. If you can't get low battery logo charging this is it.
Just curious does the device switch itself on or show any signs of life when plugging into a charger?
You can also test with a charged battery whether the phone will try to turn itself on when you turn the phone off and plug in the charging cable.
by
thanks guys, where can i send it to get it fixed?
by
There are several good micro-solderers on this forum. You can check my profile if you want to learn more about my services.
by
Add a comment
Add your answer
kari19 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 85
