Leaking from the bottom, very loud during agitation cycles
I have the portable kennore washer model #110.49722992. It has started leaking at the base of the bottom, front of the machine. As I've continued to use it more water has started leaking out over time. Also during the agitation cycles it makes an incredible loud sound as the agitator goes back and forth. I was wondering if you might know what parts I would need to fix it. Thank you!
Add a comment
1 Answer
Sounds like it's the water pump, that's what my hotpoint did when it failed. Or one of the clamps on the pumps has come off/loosened.
Add a comment
Add your answer
J Evans will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 89
